Simple Alternator Query - Don't Want To Fry Myself!
Just a quick query folks. Have decided to try and sort the elusive intermittent info centre I have. Before I start checking all the contacts around the alternator and then behind the dash, what precautions do I need to make to ensure I don't electrofry myself?!
Does the alternator generate any current when the engine is off or do I still need to stay away from certain points regardless?
Thanks!
Thanks!
When your engine is not running your alternator is NOT generating any power. If you want to play it extremely safe you can also disconnect your battery. That way there will be no power at all.
Whoever said : " A Volvo cannot be tuned ?!? "
Name: Goldlocks // Type: TURBO // Year: 1988 // Colour: 435 Saffron Pearl // Engine: B18FT (1.7) Rica chip, Custom Volvo widebody and lots of ICE
Re: Simple Alternator Query - Don't Want To Fry Myself!
Message content removed.
- SteveR
There are several cables bunched together that earth near the alternator - if not earthed properly info centre acts peculiar or not at all - its an odd one but it worked for me.
Steve Robson
![Image](http://www.smr46.co.uk/volvo/ringsml.jpg)
At Nurburgring (pic Suddy)
No longer a 480 owner![Sad :-(](./images/smilies/icon_sad.gif)
- 2127
Thx Ally for what I call a very clear explanation of basic car electrics. It is one of the reasons I started visiting this forum: getting knowledge about some things that may be evident to others, but certainly not to me. Yes, I know one shouldn't put + and - together and I can perform effectively to a certain level when converting in-house electrics, but car electro is a different beast altogether. Now I feel more confident tackling some jobs that are on my list for far too long already.
Much obliged!
Greetz,
Peter
Much obliged!
Greetz,
Peter
Less is often more.
- robkendall
haha.....ive got two scars down my right forearm that would disagree with you.....was tightening the starter mounting plate on the turbo when i had it, the ratchet slipped off the nut, hit the + on the battery and earthed....it was lying down my arm at the time.ally_v wrote:None! The 12volts used on cars is harmless. .
if you wanna be safe, take the battery off altogether....no harm in it for a couple of bolts.
rgrds
rob
I also did the same thing. so remove the battery!robkendall wrote:haha.....ive got two scars down my right forearm that would disagree with you.....was tightening the starter mounting plate on the turbo when i had it, the ratchet slipped off the nut, hit the + on the battery and earthed....it was lying down my arm at the time.ally_v wrote:None! The 12volts used on cars is harmless. .
rgrds
rob
- MrHyde
So now i know why the TÃœV demands that the + connector at the battery has a cover on int ..
But it's as ally wrote, if you connect + to earth directly there will be really high current
Hauke
Hauke
Fog Lamps, n.:
Excessively (often obnoxiously) bright lamps mounted on the fronts
of automobiles; used on dry, clear nights to indicate that the
driver's brain is in a fog. See also "Idiot Lights".
- 2127
martinholmesuk wrote:if you wanna be safe, take the battery off altogether....no harm in it for a couple of bolts.
rgrds
rob
Would do it anyway, isn't worth the risk. Saw some huuuuuge sparks once coming out of a battery. Did the trick!
![Shocked :shock:](./images/smilies/shocked.gif)
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
Less is often more.
