left headlight no dipped beam.
Help please. When i turn on my headlamps only the right hand one comes on. both work ok on full beam no light in left one on dip. I've checked the bulb[left] seems fine, replaced with another still no left dip checked fuses and connections. anyone got any ideas please.
- haz@nocturnal_development
- 480 Rookie
there's only a few things to check and u've done the obvious.
how have you checked the bulbs?
have you swapped bulbs from each side,
check fuses,
check earths,
check wiring from switch to light,
check there's power from light switch.
haz
check fuses,
check earths,
haz
reanualt 5 campus, Volvo turbo conversion, hybrid T28, -31 actautor, external oil cooler, THS intercooler, rear radiator, large throttle, Adaptronic ECU, cossie blue injectors. results recorded '06 (21 psi 228bhp/229lbs),(23psi 12.6 @108mph)
Hello. I just bought my first 480 and I have the exact same problem with my headlights as Joe.
The left hand one wasn't working when I bought it. So I've just changed the bulb. Now it works when the pop-ups are on but not at all when the pop-ups are down but the right hand one is really bright.
Just wondering if you managed to get your problem fixed Joe and what was the cause?
I can top trump this,
Both my dips dont come on at all, my main beam is fine and my side lights are also fine
I have changed all the bulbs, and checked the wiring, didnt know about the relay but i guess that they should be fine cos of the main beam coming on
before the lights went completley the indicator used to make them flash on and off, and i had the correct bulbs in ?????
I am perplexed
can any one help with this, i am not online a lot anymore and would be greatful if some one could call me with a solution my number is 0771 678 0405
mac
I am perplexed
mac
You are as good as your last audience
