NO!! Infocenter stopped working..
Anton_K
Post by Anton_K » Sun Jun 19, 2005 9:55 pm
Hi,
All of a sudden the infocenter stopped working..
Where to start looking for the problem? I don´t like guessing how much fuel there is left..
I took out the radio a few days ago from the car(the car has no radio at the moment), could I have pulled of some infocenter wire? I doubt it becouse it did work after the radio was out at first.
Any :help: appreciated
rpruen
Post by rpruen » Sun Jun 19, 2005 10:40 pm
Maybe the wires for the radio have shorted out and blown the fuse?
The radio and infocenter oddly share the same fuse :crazy:
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
chriskay
Post by chriskay » Mon Jun 20, 2005 9:06 am
Try shining a torch on the infocenter. If you can see the figures, the halogen bulb has failed.
2 Kings; Chapter 9 Verse 20
Big Brother
Moderator
Post by Big Brother » Mon Jun 20, 2005 9:18 am
The fuse that controls the info centre also controls the radio and fag lighter so I would try that first.
Ad
2001 V70
guitarcarfanatic
Post by guitarcarfanatic » Mon Jun 20, 2005 9:27 am
If neither of these options work, it could be that you have dislodged a cable at the back(mabe the one which goes onto the info centre controller or one at the back of the dash). Try the easy options first otherwise remove the dash and check all wires are making good contact. Also may be worth checking the brown PCB on the back of the instrument cluster for any visible soldering faults. Lots of threads on broken info centres and soldering the PCB in the elctrical forum.
Good luck mate and I hope its something simple! Rob
Previously...
1989 Black ES - Great runner
Anton_K
Post by Anton_K » Mon Jun 20, 2005 1:50 pm
Thanks for all replies :D
I checked the fuse, and with a smile on my face I discovered it was blown...then I replaced it with a new one and started the engine..and suddenly I didn´t smile anymore.. :( It didn´t work :angry:
I also tried shining a torch on the infocenter, no figures..
Guess I now have check the PCB(what does it stand for?) and that all the wires are making good contact.
Regards,
Neo
robkendall
Post by robkendall » Mon Jun 20, 2005 2:25 pm
pcb = printed circuit board
rgrds
rob
Anton_K
Post by Anton_K » Mon Jun 20, 2005 2:48 pm
Thanks, now I now what I´m dealing with.
Post by pol » Mon Jun 20, 2005 3:37 pm
Maybe you've blown the fuse again? As was mentioned earlier, have you insulated the power wires from your removed stereo?
Matthew Brennan
Post by Matthew Brennan » Mon Jun 20, 2005 6:01 pm
Check all the leads comming of your alternator. If one with a hoop has broken off re-attach it. Its an earth wire i think but my car ran fine without it 4 ages whilst i wondered what was wrong with my infocentre.
Anton_K
Post by Anton_K » Mon Jun 20, 2005 7:12 pm
That was what I was hoping for but the fuse is okey. I have also isolated the power wires from the removed radio.
I checked it, but it looks fine.
Thanks for the tips, guess I now need to remove the dash and check that all the wires are making good contact when I have a free day.
I´ll be back :)
coyote1980
Volvo 480 Club Europe CREW
Post by coyote1980 » Thu Jun 23, 2005 3:42 pm
Not sure, but check the cable from the info-center selector on the dash all the way to the back of the instrument cluster. Are both ends properly connected?
Daniël Wilten
Volvo 480 Turbo Collection 1995 Dark Green Metallic
Club Europe chairman/webmaster/forum admin
Anton_K
Post by Anton_K » Fri Jun 24, 2005 9:48 am
Okey :) I will check it next week and tell how it went! Have a good weekend!
SteveR
Post by SteveR » Fri Jun 24, 2005 10:44 pm
There are 3 wires to earth, but not brown, which go to the alternator either the bracket or an extended bolt from the end of the alt, ive seen both types.
On my previous LtdEdtn they had all come adrift, joined together and earthed and all was ok.
Steve Robson
At Nurburgring (pic Suddy)
No longer a 480 owner :-(
Anton_K
Post by Anton_K » Sat Apr 28, 2007 8:21 am
After loosing my hope about the Info center, and already started collecting replacement parts, I´m so happy to announce that it´s working! :hopping:
The car was at my local Volvo dealer, cambelt change, and when I picked it up..on my way home..I notice it was working :)
Must ask what they did, and I didn´t!!!
Anyway thanks for all replies :)
:hopping:
Matthew Brennan
Post by Matthew Brennan » Wed May 02, 2007 6:54 pm
Hi Anton, they probably a cable with all of the moving of engine bits, most likley the cable that runs from the speedo sensor up from under the engine to under the battery plate.
Hope it holds up!
Anton_K
Post by Anton_K » Wed May 02, 2007 10:58 pm
Hi Matthew!
That sounds very likely..if it would stop working I will check it, good point :)
I took a photo on my way back from the dealer:
Had a chance while waiting on the car to test drive a C30(2.0l, not the one in the pic), and I must say though the engine felt responsive and somehow light, my 480GT 2.0i impressed me again with the smooth ride and the powerful low rpm:s :) And then there is the character! :D
Regards,
Anton
jonhanks
Post by jonhanks » Thu May 03, 2007 8:25 pm
Does anyone have a picture of the alternator with the ground connections from the info centre?
thanks
ozturbo
Post by ozturbo » Fri Jun 01, 2007 2:31 am
Matthew Brennan wrote:Hi Anton, they probably a cable with all of the moving of engine bits, most likley the cable that runs from the speedo sensor up from under the engine to under the battery plate.
Hope it holds up!
Where exactly does the speedo sensor go and what does it look like? I would like to check mine but don't know what I'm looking for. My info centre has a mind of its own and comes on if and when it likes. All the alternator leads were redone the other day when the alternator was replaced and I have cleaned the connections on the back of the instrument panel before. I haven't cleaned the plug on the computer in the left hand door pillar yet though.
1990 Volvo 480 Turbo white
1988 Alfa 75 3 litre V6 red
1990 Alfa 75 Potenziata 3 litre V6 black
1992 Alfa 164 3 litre V6 red
1981 Alfa GTV 2 litre red
Post by glasgowjim » Sat Jun 23, 2007 10:14 pm
sorted out my charging problems by changing alternator , took instrument panel out and resoldered the grey info centre leads replaced : all worked fine now the info centre stopped working definately a bad connection but when the socket was waggled the dash lights under the info centre went out and then on again.
Will try again tomorrow
