Flat battery
Flat battery
I wonder if anyone else has ever had this problem? In the past with all my other 480s if the car was not been driven for a week or so the battery was always flat and it would not start. Not an old battery with any of them but it was a nuisance. In the end if we were going to be away for more than a few days we disconnected the battery and all was well. Any thougts as to why this would happen and if there is any other way of avoiding it in the future other than diconnectig
1995 Celebration number 418/480. dark Red
2004 Mini Cooper
2004 Mini Cooper
- bbf
i would say interior lights, locks lightening, aux water pump. just wait 5 minutes and you'll be fine!
'86 480 ES, RIP :(
'91 480 Turbo, RIP :(
'93 480 2.0, RIP :(
'86 480 ES, RIP :(
'93 480 2.0, RIP :(
- bbf
delet it or edit it.
give 5 minutes for all timers to set down. so the car will go to lowest power drain. than check the current drain from batt. before you do this, open the engine compartment (bonnet) and stick something to the bonnet lock, where the switch for open signal is. dont' disconect the batt without ampermeter, the timers might start again..
'86 480 ES, RIP :(
'93 480 2.0, RIP :(
'86 480 ES, RIP :(
'93 480 2.0, RIP :(
I think what is being said here is you need to check the battery connected to the car by having the hood open. But having the hood open is also opening a switch in the bonnet lock. So if you find a good way of checking for battery drain, open the bonnet, lock the doors, stick something in the bonnet catch to trick the switch into thinking the bonnet is closed, then connect your multimeters in whatever way you would to check this problem...
Oh Dear, I will have to get my Son in Law to decipher all that .I am a completely illiterate elderly female as regards the workings of a car. Thanks for all the advice anyway. I appreciate it.Where do you find the delete button when you have already sent the post? Fairly computer illiterate too.
Just posted this and low and behold there was the edit button on the afar righthand corner which took me straight back to the post box so now I know a little bit more
2004 Mini Cooper
2004 Mini Cooper
