Another speedo question
- 480 Rookie
Just had the soldering iron out and resoldered all the pins where the connectors join the pcb. I now have a working temperature gauge to go with the fuel gauge and tacho but.......
the speedo still doesn't work
May try resoldering the pins again as the first two I did were for the speedo so may not have been done very well. (Haven't had much use for a soldering iron since I left school twenty years ago so a bit rusty on technique). Or have I missed something else as I have only done the connector pins.
Anthing else that may have needed the attention of the iron or should I now be looking elsewhere to solve the problem. The speedo does still work occasionally, like this morning for about five minutes.
Garry
Garry
- 480 Rookie
Tried resoldering the first couple of pins. Went out after refitting the dash to give a go. It teased me for a couple of miles beore going on the blink again
Is it best to solder the joints on the pcb or mfu. Does this still apply to the anologue type gauges which I have or just info center types, there is a small pcb that comes off. Does this perorm similar functions as for infocenter types or is it totally different in operation.
Garry
Garry
I have absolutely no idea!Does this still apply to the anologue type gauges which I have or just info center types, there is a small pcb that comes off. Does this perorm similar functions as for infocenter types or is it totally different in operation.
Do you mean you have no small pcb? i think the small pcb is just for the info centre types, and/but it appears on mine to be connected to the speedo circuit.
I should just resolder everything, y'know what volvo's wiring s like, if disconnecting the two red wires for the radio kills the info centre, god knows what needs to be connected for the speedo!!
- 480 Rookie
- Murf
aw shit!!
sorry, i totally forgot to tell you how to fix your analogue gauges!!!!
sounds like you got it sorted anyway!!
i had the same problem with my speedo and it turned out (after much wailing and gnashing of teeth) that it was the actual sensor on the gearbox that was the problem.
it is, however a nightmare to get to and remove but fortunately i found that by tapping it with the tip of a very long screwdriver brought it back to like and it has worked fine ever since!!
sensor is on drivers side at the bottom of the gearbox, haynes will show you where it is better!!
sorry again!!!
sorry again!!!
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
1992 480 Turbo
2007 Focus ST
- 480 Rookie
I am glad you have told me where to find the sensor as the more I look the less sure I am of where it is especially as the Haynes manual shows it so well!! I think they only say it's on the right of the engine and never say which which way you are looking at it from. I can only cope with driver and passenger side, never been sure about nearside/offside even.
Thanks again
Garry
Thanks again
Garry
