Rotary headlight switch illumination
royhedger
Post by royhedger » Sat Apr 20, 2024 7:32 pm
The night lighting for the rotary headlight switch isn't working. I thought that the bulb had gone so when I pulled the dash today I replaced it.
It seems I'm not getting power to this little bulb. Is it fused somewhere? Is there a connection other than the bulb holder which may have come loose?
TIA. Roy
White 1990 480 Turbo Auto
Re: Rotary headlight switch illumination
Post by jifflemon » Sun Apr 21, 2024 5:07 am
It’s not fused, deffo not blown? Is it seated ok? Do the rest of the bulbs work (heater panel, seat heater panel, ashtray)
royhedger
Post by royhedger » Sun Apr 21, 2024 3:10 pm
Yes it's seated ok. I tested the wires and no power to them. I'll just have to trace the wire back to where it's broken if it's not fused.
I'll do it when I next pull the dashboard out to find the annoying vibration...
