Mysterius cable on battery pluspole shoe
Greengrass
Post by Greengrass » Wed Jun 07, 2023 5:00 pm
The battery plus poleshoe broke yesterday so I have to fix a new one.
But how do I get the old one lose?
And what is the wire/cable that is connected to it?
480 ES - 92 lavender - bought it 2008, every day car, winter-summer
480 ES - 90 red - bought it 1992
460 GLE - 91 red - over 20 years old and absolutely rustfree!
Lexus RX300 - 00
Greengrass
Re: Mysterius cable on battery pluspole shoe
Post by Greengrass » Wed Jun 07, 2023 5:10 pm
In fact there is four cables connected to the shoe.
a big red one, probably the main plus electric
a thin blck one, connected separate
and then two cables which goes threw a sort of box
when I turn the whole cable, it makes a clicking sound.
My suspicions:
Have it maybe to do with alarm or immobilizer?
Lexus RX300 - 00
Post by jifflemon » Thu Jun 08, 2023 4:53 pm
So, typically.....
You'll have a single thick red positive cable that is soldered into the terminal post. Then around 5-6 cm down that cable, is a black box that branches out two further red cables. One goes to the alternator, one goes to the inside of the car.
the thin Black one sounds like something someone has added - you'll need to follow that.
Typically, you cut the terminal post off, add a spade connector and use a bolt on style post. Or you could use Jay-Kay-Ems solution - I have!
