Wiring issues?
Wiring issues?
Just bought a 1987 volvo 480ES and one of the issues with it is that the popup headlights last tested didnt go down and when tried to get them down white smoke comes from the ignition key area. And im clueless on what it may be
Re: Wiring issues?
Hi there Suovas, welcome to the club.
Firstly, whereabouts you based? Its just that german cars had a different mechanism to the rest of the 480s due to stringent laws, as such its a bugger to fix. Pop up issues are usually with the relay or the plastic pivots on the light itself, I am extremely surprised to learn of white smoke from the ignition switch, have never heard that one before
Re: Wiring issues?
I think that Joseph Lucas had a small market operation selling jars of the stuff?MisterH wrote: ↑Tue Sep 07, 2021 8:26 amHi there Suovas, welcome to the club.
have a read here
https://www.mgexp.com/forum/mgb-and-gt- ... y.3765167/
seriously though smoke is not a good idea, sounds like overheating in a serious way, relays for headlights are 'different' I'm sure Jeff or Brinkie will keep you right
Re: Wiring issues?
Headlight adjustment isn’t electric, it’s utter garbage hydraulic pushing everything up/down— that won’t be your issue.
You need to get the black part of the dashboard out (instructions on here) and report back which wire looks like it is heat damaged. Don’t try to repeat the smoke thing again unless you have fixed this— your whole car could go up in even more smoke and flames!
Re: Wiring issues?
Hey!
I found a problem in the headlight control toggle switch, they are weak, look at it first. for good it must be unloaded with an additional relay as I did.
Volvo 480 Turbo!
I was born and live in Siberia!
