Wipers and door mirrors
JohnO
Post by JohnO » Sun Jun 06, 2021 2:49 pm
Hi all,
Was out in the celeb the other day and couldn't get the wipers to work. As everything else seemed fine, I assumed it was the fuse.
Had a wee look today and realised that none of the stalk functions are working, wipers, washers and rear wipers.
Checked fuse 6 as the kid says and fuse 9, I'm think it was. And both fine. Tried new ones anyway, but nothing.
I also noticed that the rear view mirrors are not adjusting also.
Thoughts? Other things to try?
JohnO
Central Scotland
M ybw Celebration 51/480 just adopted from fellow member
F ggg Black 480 es 1989 - garaged for 20 years, rotten arches
Re: Wipers and door mirrors
Post by jifflemon » Sun Jun 06, 2021 2:57 pm
If nothing on the stalk is working, and there’s not a fuse gone, it could be the stalk itself.
Doesn’t explain the mirrors of course….
JohnO
Post by JohnO » Sun Jun 06, 2021 3:19 pm
Thank you,
They could be random coincidences.
Having a wee look at the instructions on the cem diagnostic, see if I can work it out.
JohnO
Central Scotland
Post by MisterH » Sun Jun 06, 2021 5:05 pm
That is odd, mine played up yesterday only the wipers all went on simultaneously with no stopping them, which means a new CEM is in order, however your problem could be related to the stalks methinks...
Post by dcwalker » Sun Jun 06, 2021 8:50 pm
Without checking I think they must be random coincidence.
Wipers are CEM controlled but it could well be the stalk - I have a spare if you want ind to try. Mirrors...have you disturbed the centre trim round the handbrake?
JohnO
Post by JohnO » Tue Jul 06, 2021 8:05 pm
Sorry, its been a wee while.
Checked all my fuses and all seemed OK.
I managed to work out a bit of the self test, I had no position 4!
I managed to put it through the full cycle and the both sets of wipers and the washers work , so it must be the stalk, hopefully.
Does anyone have one?
Thanks,
John
JohnO
Central Scotland
Post by dragonflyjewels » Tue Jul 06, 2021 9:25 pm
I have a spare stalk you can have, pm me your address and I'll get it sent off
JohnO
Post by JohnO » Tue Jul 06, 2021 9:46 pm
Thank you, it's dc to the rescue ! This time
JohnO
Central Scotland
Post by dcwalker » Wed Jul 07, 2021 4:58 pm
Stalk is on its way...
JohnO
Post by JohnO » Thu Jul 15, 2021 2:48 pm
Replacement stalk received, cleaned and fitted - Still nothing.
Had another look at the fuses and both seemed fine.
Took the relays under the bonnet out one by one and cleaned and fitted - just in case. Nothing.
The arthury offered me another CEM - so hopefully we can try that out soon.
Hoping to get the MOT done soon
At least we've not had rain for a wee while!
JohnO
Central Scotland
JohnO
Post by JohnO » Tue Jul 20, 2021 6:56 am
With a little help from Arthuy, he buzzed the relays and we managed to get the wipers AND mirrors going. It looks like the relay k is a bit flaky as they mostly now work. There were also a few brown wires, that looked like they melted a little.
I'm about to look for the relay part numbers, but if anyone knows them, could they let me know.
JohnO
Central Scotland
Post by dcwalker » Tue Jul 20, 2021 7:26 am
Good to see progress John, and I have PM'd you...
Post by jifflemon » Tue Jul 20, 2021 9:40 am
Brown wires are typically earths.
arthuy
Post by arthuy » Fri Jul 23, 2021 6:30 am
arthuy wrote:
Thu Jun 22, 2017 12:59 pm
This diagram is the five pin version showing the difference between the relay pins, but the 4 pins are the same without the centre pin (87a).
Just in case anyone stumbles across this post with the same issue the part numbers for the correct 4 pin relays are below.
Volvo: PN 472210/01
Pearl: PR06
Bosch: 0 332 019 451 / 0 332 014 406
BMW: 61311354393
Halfords: HEF555
siemens: V23134-K52-X249
One of the few parts you can probably get at halfords.
