Another OCD fixed
frenchfries
Another OCD fixed
Post by frenchfries » Sat Aug 26, 2017 6:17 pm
Just realised that the lovely green light around the ignition only comes on if the roof light is set to come "on" with the doors.
Re: Another OCD fixed
Post by jifflemon » Mon Aug 28, 2017 11:05 am
Oooo I didn't know that! I have the lights off because it's not in daily use, so I wonder if that's the problem with mine!
frenchfries
Post by frenchfries » Mon Aug 28, 2017 3:23 pm
I only realised because mine are usually off to save on battery when I do (fix) something in the car (and the door is opened). I was bracing myself to change the bulb behind the ignition and now that I have replaced the battery the ceiling lights are on again and ....... et voilà :)
I hope it works for you as well.
