Dash lights
Dash lights
I've not had this car long, but have noticed that the dash lights for the fan speed control switch, clock & the info centre switch are not illuminated, how would I be able to check the bulbs, do I need to take the dash out or can the switches be removed individually ? Many thanks.
- doingitsideways
Re: Dash lights
They just pull out from the dash as seperate units, with bulbs in the back of each.
Although, the Info Centre switch isn't illuminated.
Hammers can't fix a 480!!!
Re: Dash lights
Thanks for your reply, is there any special technique to removing them ? Clips , lugs etc ?doingitsideways wrote:They just pull out from the dash as seperate units, with bulbs in the back of each.
- doingitsideways
Re: Dash lights
Not really.
Just something like a small scraper or something else with a flat blade to gently lever them out.
A flat headed screwdriver would work, but may leave a mark.
They seldom put up a fight though to be honest, they're only held in by little spring lugs.
You could probably pull them out by hand. I have before!
Re: Dash lights
Came out easy enough, anyone know where i can get the tiny wee bulbs from ?
Re: Dash lights
any motor factors or halfords just ask for p bulbs.
Re: Dash lights
Thanks Jim.glasgowjim wrote:any motor factors or halfords just ask for p bulbs.
Re: Dash lights
Just FYI, the hazard warning switch is a different wattage to the rest. I think it's 0.36W and is rather difficult to get hold of but looks silly with a 1.2W (which everything else is).
Re: Dash lights
Think its RS part number 655-9659 if you fancy buying 10.
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
Re: Dash lights
I do! Thanks for the infoeye of ra wrote:Think its RS part number 655-9659 if you fancy buying 10.
