Can anybody tell me please how do I disconnect this multi pin connector block?
http://s1328.photobucket.com/user/anarc ... sort=3&o=1
http://s1328.photobucket.com/user/anarc ... sort=3&o=0
I have some odd electrical problems on a car that has been laid up for some time
How do you disconnect block connectors
Bob Blackman
Engine Punk blogger
Author of The Horsepower Whisperer and The Wormton Lamb
http://www.anarchadia.co.uk
Volvo 480 Turbo, Hillman Imps,
Engine Punk blogger
Re: How do you disconnect block connectors
for the top photo, pull the pin/slide down,
in second photo pull towards left,
are these for the door wiring?
Thanks for such a prompt reply
These are behind the glove box. I want to check connections for corrosion as the car turns over but won't start and there are some other odd electrical affects.
These photos are actually front and rear views of the same block connector. How far out should I pull the pin? It comes out so far and then I can feel some resistance.
Bob Blackman
Engine Punk blogger
Engine Punk blogger
With this type of connector you pull the side with the 2 lugs outwards and the connectors relase
the lugs are the bits sticking out on the top picture bottom side.
All those connectors work the same way with different colours for each set of wires.
Bob Blackman
Engine Punk blogger
Engine Punk blogger
