The usual Pop-up problems
ChrisDK
Post by ChrisDK » Sat Sep 06, 2014 12:21 pm
Sorry if You have read about this a trillion times, but I need some advice here.
The problem seems to be that the pop-up don't pop up, leaving me with no lights. this is what I have tried so far
1: changed the headlamp control relay - no changes
2: changed or at least tried to change the head lamp control contact on the dashboard.
3: changed all fuses, just to be sure
4: wiggled about with the pop-up relay (with the bonnet microswitch disabled)
5: manually checked that the pop-up motor is not seized
Before the problem started, as long as the ignition was on - the parking lights would light no matter the position of the headlamp control contact. Now they only light in position two and three. Before the rear fog light would only work with the haedlamp control contact in position three, now the don't work, and the pop-up don't pop-up. I'm fussed about what the problem is ? could it be one or the other pop-up relay?? (and how do I check which one it is?)
Advice needed :)
Thx Chris
Re: The usual Pop-up problems
Post by glasgowjim » Sat Sep 06, 2014 3:41 pm
Just taking dogs for a walk will reply to you in detail later on tonight don not worry I have fixed more popups on 480 volvos than practically anyone else on the forum :lol:
Post by glasgowjim » Sat Sep 06, 2014 7:51 pm
first Chris lets eliminate some of the problems step by step
1 check all fuses ( you have done this )
2 make sure the daylight driving lights are both ok
3 go to relay box and remove the tall popup relay now bridge the connection for each side . When bridged the popup on that side should go up and down.
then get back to me on your results .
The rear fog light problem can be easily solved , I had a major electric problem with the front and back foglights and solved it after about half a day .
1 open the rear hatch and remove the rear trim panel locate the connector for the rear fog light disconnect and connect to a multimeter set for voltage measurement turn on the rear fog light at the switch is there a voltage reading ?
If not you will need to alter some wires behind the triple switch but again let me know the result of your test.
ChrisDK
Post by ChrisDK » Sat Sep 06, 2014 9:13 pm
Thx Jim :)
I will get back as soon as I have tryed your suggestions.
Regards
Chris
ChrisDK
Post by ChrisDK » Mon Sep 15, 2014 6:40 am
A little update.
I felt a bit uncomfortable bridging the connections, so instead I replaced the tall popup relay, no changes, no pop-up
Post by glasgowjim » Mon Sep 15, 2014 10:24 pm
you must bridge the connections
ChrisDK
Post by ChrisDK » Thu Sep 18, 2014 4:23 pm
OK, so I bridged the connections. Yes there were sparks, but no fuses were harmed :)
the result: movement of the pop-up's so the motor works.
Post by glasgowjim » Thu Sep 18, 2014 4:40 pm
Now you lnow the problem lies further back up the circuitry. 2 relays wont be duff you have changed the rotary switch so I would now suspect the cem but let me think about it for a while as there is one more thing to try.....
doingitsideways
Post by doingitsideways » Thu Sep 18, 2014 8:18 pm
glasgowjim wrote: let me think about it for a while as there is one more thing to try.....
Me thinks Jim's gone for a hammer! :nuts:
Hammers can't fix a 480!!!
Post by glasgowjim » Thu Sep 18, 2014 9:14 pm
No its electrical ! :lol:
Robou
Post by Robou » Thu Sep 18, 2014 9:34 pm
That is how brains work.
Too old to bother
480 Turbo midst '91
ChrisDK
Post by ChrisDK » Fri Sep 19, 2014 3:10 pm
glasgowjim wrote:Now you lnow the problem lies further back up the circuitry. 2 relays wont be duff you have changed the rotary switch so I would now suspect the cem but let me think about it for a while as there is one more thing to try.....
Ahmm to be honest, I did not change the rotary switch, what happend is that I discovered that there are differenses from a LHD to RHD and in an attempt to modify the switch to fit a LHD, it kind of broke. This was one of these "don't do this at home" moments with little springs all over the dining room. A new one is on it's way but won't be here until sometime next week. Would it be an idea to try and bridge the rotary switch ?
ChrisDK
Post by ChrisDK » Tue Oct 14, 2014 12:02 pm
So I'm Back. After three long weeks I finaly received a new rotary switch, it was delivered with snail mail :kill: however, it did not change annything. Still no pop-up. A couple of days ago I switched the CEM for an old one that I have lying around
(readers of my 480 thread will know that it's the one without working indicators) just to try. But that made no difference. so it dosn't seem to be the relay's, the rotary switch or the CEM so what is left to test?
Post by glasgowjim » Tue Oct 14, 2014 1:37 pm
Is your rear fog light still not working ?
not a random question !
ChrisDK
Post by ChrisDK » Tue Oct 14, 2014 2:44 pm
No, still no rear fog lights. I can't remember if I already mentioned this, but before the DRL would automatically turn on, but today I manually have to turn the rotary switch to position 1 to get DRL light.
jamesy12345
Post by jamesy12345 » Tue Oct 14, 2014 5:55 pm
Hi Chris, I guess if you have to turn the rotary switch to get any DRLs, the 4 watt side of the bulbs are not lighting up. Not sure if that helps with the diagnosis but just sayin!
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
