Hello. Could someone please give me some information on the Volvo 480 cluster.
Which Pins from the grey and green plugs on the back of the cluster power the Information Centre?
Any help regarding how the Information Centre works would be much appreciated.
Info Centre Multi Plug Pins
- doingitsideways
Re: Info Centre Multi Plug Pins
That's actually like asking for the meaning of life!!
There arw actually some downloads available from the club homepage that may prove useful, as long as you can read Dutch!
Steve
Steve
Hammers can't fix a 480!!!
the HBOL does have various circuit diagrams, some are sort of true some are not, it does seem to vary between models/year etc
for me the speedo would ONLY work when powered up hanging in the front footwell. everytime it was fitted back into place it would die, it might have been the connection to the MPG part etc so it now has a DIRECT power feed from the fan switch illumination (I should have had a spare connector that I could plug in without removal of dash-board)
can supply extra connectors (green + grey) for info centre if needed.
Jim
was the offer of connectors directed at me?
I meant a 'loose' single connector out the front of the dash-board that I could plug into the mpg trip side to confirm/deny that I'd found the fault. I am happy enough to accept that the mpg is OK anyway!! :-0
