Hi,
I started my car this after noon to be greeted with a high pitched frequency in a constant tone, it goes.off when I turn my lights on, any ideas?
high pitched noise
high pitched noise
'90 940 GL 2.0l Estate
'08 XC90 D5 SE Premium
- doingitsideways
Re: high pitched noise
No idea.
Just keep the lights on.
Or turn the radio up.
Job done
Steve
Job done
Steve
Hammers can't fix a 480!!!
It could be the alternator bearings or one of the belts.When you put the lights on it increases the load and takes up the free play. Probably rubbish, As it normally works the other way roundbut worth a look!http://www.volvo-480-europe.org/forum/p ... 12&t=34337#
Hmmm..but it's more like an electronically made noise if.you know what I mean? Not like a worn bearing, it gets louder with the radio on, thanks though!
Is the sound coming through the speakers?
The radio could be picking up the interference from the alternator or other electrical systems.
Pretty well everything can create interference but the alternator will be favourite, it can create all kinds of bangs, whistles and whines which can be amplified by the radio.
This would explain the electronic sound and also why it gets louder when the radio is on.
If there is a hint it might be coming through the speakers unplug the speakers from the radio to verify.
Regards
Regards
Ok thanks! It seems to have gone away anyway! For now...haha
