Hi all.
i wanted to make all the lights turn on only when i rotate the switch. Now the lights are on even if i turn the ignition on. I dont want this! thanks guys!
playing with lights
Re: playing with lights
are the lights wired via module, I have considered if I had major gremlins at any point, to more or less create old style wiring for lights etc, but safer to leave alone whilst it works
there is a wire you can clip if you mean turning drl, dash and tail lights off.
