Hmm...
got in the car this morning and it seems my info center has given up the ghost!
It has played up before, about a month ago, it refused to do anything a couple of times, but after a few minutes of driving, sorted itself out.
Also been losing it's memory.
Oh... Once the display went all crazy, flickering all kinds of nonesense, but again it sorted itself out.
I've been in and out of the car all day and there's still no signs of life.
So, anyone got any ideas??
Cheers,
Steve
info center
- doingitsideways
info center
Hammers can't fix a 480!!!
Re: info center
If you shine on it with a strong light, do you see anything indicated? Then it's the halogen bulb.
Other options are bad connection from the connectors and bad connection to the lcd display.
- doingitsideways
Re: info center
It's started working now, when it did, it ran through the usual oil ok, range, then onto the selected function.
It's got me puzzled!!
Steve
Steve
- chriskay
Re: info center
It sounds to me very much like poor connection in the two multi plugs at the back. Probably best to remove the dash panel and take them off and give them a good squirt of contact cleaner. Worked on mine when I had the same problem.
2 Kings; Chapter 9 Verse 20
- doingitsideways
Re: info center
Ok, i'll give it a try.
Thanks.
Steve
Thanks.
Steve
Re: info center
If you need one, I still have the info centre from mine
- doingitsideways
Re: info center
Thanks Kez,
I'll have a look at the connections at the back and go from there.
Prob be weekend before I get round to it though!
If I need yours, I'll PM you.
Thanks,
Steve
Thanks,
Steve
