I know this topic isn't new, but I have an anoying thing going on with my alternator belt. When I start the car up, the alternator belt will start squeeking. It only does it when you drive away or use an electronic device wich needs alot of power.
After a few squeeks it won't be heard untill the next cold start.
It's also pretty loud, looks like a dozen of cats getting crushed
I replaced both of the belts (alternator and power steering etc.) and I don't have the idea that the belts must be tightend more, while they are allready pretty tight. (the one for power steering must be more tight)
There's also the problem that the car loses a lot of batterypower over night so ti probably needs a lot of power from the alternator at startup.
Does anybody have experience with this? Any ideas
squeeking alternator belt on startup
- Williewammes
- martinholmesuk
Classic quote of the week!It's also pretty loud, looks like a dozen of cats getting crushed
Maybe the pullys are worn? , as for the battery loss view this http://volvo480.northernscum.org.uk/for ... ht=battery
good luck dude
Audi TT
Audi TT
- Williewammes
Jow,
I'll check the whole electrical system for power leaks. is the only way to find out.
Maybe it's the alarm wich is causing the leak. One of my door sensors is broken, but I don't know if this wil cause power leak.
Luckely I'm using the car every day so it wil start without problems, but you can hear that the starter engine can't reach it's maximum output.
Anyway, I'll let you know when it's solved. It will probably, All the previous problems (challenges) have been solved thanks to this forum
And for the alternator, I have a spare one, so I'll replace it and see what hapens. Not a nice job thow, little room under the bonnet, cold environment , and little time
The search continuous........
- Williewammes
Guys,
Replaced the alternator yesterday, Tommorow, what a peacefull sound. Not a sound, only that of the engine.
Looks like it was the pulley indeed. While I had a spare alternator, I thought it was easier replacing the whole thing than just taking the pulley off. It was pretty well attached and couldn't loosen it.
Anyway, one happy 480 driver here. by the way, the neighbours are happy too
So, thanks again, you were right again.
Greets,
Williewammes
Volvo 480 turbo Paris bleu metallic 1992.
Volvo 480 turbo Grey metallic 1987
Check: www.wdesignonline.tk
Williewammes
