maxwell98
Post
by maxwell98 » Sat Mar 05, 2005 7:43 pm
Hi there
Am a 480 newbieand have discovered a multiplug at the front of the engine that doesn't seem to belong anywhere. Also why is my bulb warning light on when all the bulbs are working i won't even mention the info centre
![Crying Hard :cryhard:](./images/smilies/crying.gif)
1990 Volvo 480 es Old but Gold (its silver actually but you know what I mean)
1993 black 480 turbo
1996 celebration
pol
Post
by pol » Sat Mar 05, 2005 9:11 pm
The dead bulb light isnt all that helpful. You might find its one of the day running lights. They have 2 filaments and use different ones depending on weather the main lights are on or not. Maybe you didnt notice that. Think they're bosch 566's. Multiplug at the front is probably for air con if u havent got it. There's lots of posts on re-soldering info centres around here somewhere.
Good Luck
pol
mogge
Post
by mogge » Sun Mar 06, 2005 6:29 am
Hi!
About the dead bulb warning light.
If all bulbs are ok and they light with the same power, there is a common problem. The buld indicator relay. This is located in the boot, rear left.
Because of water leeaking in to the boot, the electric components in this relay often stop to work.
Disconnect the relay and see if the problem remaines.
/Jonas
Engineer
maxwell98
Post
by maxwell98 » Sun Mar 06, 2005 10:32 am
thanks guys will check both of those
1996 celebration
