Hi,
Had this problem for a couple of months. Left one goes up and down, right one either doesnt at all or occasionally decides to work in an intermittent..i.e. jerky fashion, more often than not stopping halfway.
Now l have replaced both dampers with brand new ones as was suggested at a recent meet, and the problem is exactly the same.
One clue is that the last time it worked in its jerky fashion (right after i fitted the new dampers) l'm sure l could hear the relay clicking more often and l believe in time with the jerks of the pop up. I cannot hear the motor working to pop the light up but obviously l do not want to keep trying as l might burn it out.
Does this mean the pop up relay (which l replaced 2-3 yrs ago) is actually the culprit. There are no other symptoms and the car is fine otherwise.
Where can l get one in Norfolk? The volvo parts place here moved to Portsmouth or something daft.
Right pop up intermittent
- bbf
one of my popups did the sam: the cause was worn-out brushs of the position switch in the motor. i cleaned it and grease it and it worked. the motor itself is a bitch to take apart and even biger bitch to get it together..
'86 480 ES, RIP :(
'91 480 Turbo, RIP :(
'93 480 2.0, RIP :(
'86 480 ES, RIP :(
'93 480 2.0, RIP :(
- bbf
yeah, four nuts and a gass spring and wiring.
all nuts are behind the light, reachable from the engine compartment. two on top, one under those 2 (hard to find) an 4th on bottom. unsrew those 4 and you get your lights out. good luck with the scrapie edition!
'86 480 ES, RIP :(
'93 480 2.0, RIP :(
'86 480 ES, RIP :(
'93 480 2.0, RIP :(
