Wipers (front) running at start up
Post by Alan 480 » Fri May 10, 2024 9:47 pm
Folks
A couple of times recently we have had the wipers come on ASAP the key is moved to the 'unlock steering' postion, no fixed method of stopping them, other than lock / unlock etc (better half made the comment and I had same issue today twice, then all normal)
I know that there is an 'extra' supply that should allow the wipers to self park and if that wire or switch is broken then they just paark 'anywhere' but this would seem to be the opposite !! :cry:
I wheeched the CEM out and all looked well, not any sign of dry solder joints or water ingress, although it does seem that the box had been removed by a previous owner, only one screw holding it in place
any suggestions are welcome :wink:
Re: Wipers (front) running at start up
Post by jifflemon » Sat May 11, 2024 6:40 am
Switch would be my starting point
Post by Alan 480 » Sat May 11, 2024 9:05 pm
Jeff
OK,, that should be 'simples' as I'm sure I have a complete set of switch gear 'stashed' . . .. .
