Yellow Lights
Yellow Lights
When looking through the parts catalogue for another lighting issue I noticed that the original yellow 480 headlight bulbs for were done by having a yellow bulb cap, rather than a painted lens like the long-range driving lamps and the fog lights.
The Volvo part number for the yellow H4 bulb is 963370 which was sold as a NOS item Sweden with this pic showing how they looked:
I do love a yellow bulb and try to fit them to everything, but did find that the cap reduced output too much on the 480 so changed back to standard white. I may have another go again as I still have the caps in a cupboard.
Cap only, from Italy
https://www.ebay.co.uk/itm/Citroen-2CV- ... SwvzRX0Z8s
Cap plus bulb from UK (cap can be easily fitted to different bulb)
https://www.ebay.co.uk/itm/1-x-12V-GLB4 ... Sw88xgNR4Q
Here is my old E-reg with yellow lights at our October 2017 meet:
Re: Yellow Lights
So what are these exactly? Are they like French deep good yellow lights (never been a fan) or are they more subtle. Now you have pointed them out, they do look similar to mine which have a yellowish tint, but doubt they are the same
Re: Yellow Lights
I think yours are probably just old filaments of standard white bulbs maybe loosing a few volts to the resistance in the system if they are starting to look a little yellow to you. They look okay to me though, a tungsten filament is always nice and warm. Can you see okay with them? 480 lights are pretty good on dipped beam when sorted out with good bulbs and maximum volts/ minimum resistance to the bulb; superb when on high-beam with the long-range and fogs filling in nicely.
If you want to know how much voltage you are missing from your bulbs, pop the bulbs out and measure the voltage across each with the engine running and the bulb on. Compare this to the voltage across the battery with the engine running. If the values aren’t close, then ask Jeff for a masterclass on how to find the resistance with your multimeter as any advice I could give would be a bit vague.
The caps are exactly what they look like and give you a French yellow which is what must have been supplied in France early in production. I quite like them but the caps reduce light output compared to actual yellow bulbs— but these are hard to find now in decent quality.
Personally I just like how the world looks with yellow headlights but each to their own. Conversely, I don’t actually care too much about how they look to those looking at the car. There is a lot of debate about “selective yellow” French bulbs and I think the conclusion seems to be inconclusive. They are certainly not proven to be better from what I’ve read.
I am a convert to yellow lights but don’t think they are better than white in the dark/fog, I just find it very peaceful to drive with them, especially when it is properly dark and no other cars around so you can appreciate it more.
It’s the cold blue modern lights that I really dislike. The Avantime came with really cold blue lights from the previous owner. I have yellow HIDs in that now but am not 100% convinced yet that this was a good idea.
(Fogs don’t match, I know!)
Re: Yellow Lights
Very interesting stuff James!
Not a fan of yellow lights myself but you have certainly delved deeply into the subject and I'm pleased for you that you can achieve what you seek
I'd echo what you say about 480 lights generally being good ones. I think what helps them most is that they spend most of their time not on and folded away. On the other Volvos from quite a time-span with headlights on all the time (to some degree) and headlights continually exposed to sun-light, the reflectors degrade. I have noticed that if I look into a 480 headlight with the lights off it looks much shinier and "more silver" than, say, my C70 lights or - before I obtained brand new old stock ones - the 440 lights.
Ben - your lights look perfectly normal to me!
Re: Yellow Lights
Haha, yes the White Dwarfs on Audis are particularly dangerous, especially with a low car with a glass tailgate!!
My headlights are out of alignment anyway so I can't really see much, though they do pickup the all important eyeshine, and yes the main beams are extraordinary.
I have always preferred the warmer tone of Halogen bulbs, although the Xenons of the noughties were quite nice. I find yellow fogs to be hit and miss. On something sleek like the 406 coupe they just break up the shape, but on something like a Renault 11 they look really good
On a 480, not so sure:
Re: Yellow Lights
I trust that is some sort of parallel universe, Jeff - it can't be your driveway, there simply aren't enough cars there!!
Re: Yellow Lights
Somebody will correct me, if I'm mistaken, but aren't yellow headlights illegal on British roads?
Re: Yellow Lights
To the best of my knowledge as long as they comply with and display the appropriate British standard they are legal in the UK white or yellow.
It will be the beam alignment that could create a problem. If for example you were to use a LHD headlamp unit in the UK with the opposite dip on the beam that would not be legal. Doing such creates the same problem as parking on the wrong side of the road with your headlights on, approaching traffic simply gets blinded.
Regards
Regards
Re: Yellow Lights
There used to be some debate as I think Construction rules and MOT rules did not quite agree but it was legal but you may have had argument with a policeman who didn’t like you but probably to win that argument on later investigation.yorkievolvo wrote: ↑Fri Apr 02, 2021 10:04 amSomebody will correct me, if I'm mistaken, but aren't yellow headlights illegal on British roads?
Thankfully this has just been clarified in the recent MOT regulations overhaul and yellow is explicitly allowed: https://www.gov.uk/guidance/mot-inspect ... tion-4-1-4
Thankfully also bans awful aftermarket LED and HID scatter guns too!
Re: Yellow Lights
Espada & James - thank you for the clarification.
I've never used yellow headlights but I do prefer yellow for fog-lights.
Re: Yellow Lights
No worries. It’s good to hear from you Mike. Hopefully see you again when the our little meets are allowed.
Re: Yellow Lights
Thanks James - I must admit my first thought was to wonder about the legality of yellow headlights in the UK, so the clarification is welcome!
Re: Yellow Lights
Just looked at the MOT manual again and it now seems that yellow headlamps are acceptable but weirdly fog lights must be white or red.
