Suddenly sluggish
Suddenly sluggish
For some reason I seem to have lost power, acceleration and any speed. It is a 480 Auto Turbo (1990). All electircs have been tested and are fine - HT lead replaced. It starts fine, but driving won't go above 4000 rpm, is sluggish ie takes forever to get even to 20 mph - dicey at junctions. We managed to get 65 mph out of it the other day at a huge struggle. Although plugs, distributor cap etc have been tested it still feels like a misfire.
A mechanic worked on it and possibly damaged the fuel inlet pipe that passes across the distributor cap and into the main engine (sorry for the lack of technical terms). It has now come off completely. Although being stuck back on it has possibly lost the vacuum that it had.
Has anybody else had a similar problem? Fine one day, the next with the acceleration of a traction engine.
Help! I'm driving a Fiesta instead at the moment which really doesn't compare!
- dragon
- Volvo 480 Club Europe CREW
HT = High Tension - the leads that got from the distributor to the sparks etc
Gaz Wilson
Gaz Wilson
Hi Shaughnessy,
My BMW with Turbo suffered the same. It seemed to run out of steam whenever I put my foot down, performance was useless and could not get much of a top end.
When the dealer looked at it they said it was the air going into the turbo and explained that it was starved of oxygen. If I recall right it was a filtration/forced air system that was at fault.
Not sure if this would be similar or any of the other guys could comment on it.
Regards
Chris
Regards
Chris
- strangegame
Check the intercooler pipes, one may have come off. Had exactly the same problem on an old renault 21 turbo diesel, in that case the turbo to intercooler pipe had a 5 inch split in it and was loosing all the turbo pressure. The fact that car was a diesel won't make any difference, except it was slow usually and with the fault I was passed by a snail!
Thanks for all the advice so far. Still trying to pinpoint it but have some more info...
It won't above 4000 rpm whether it is parked or driving now. Should the turbo kick in when the accelerator is fully pressed down when it's parked?
Can anyone tell from that whether it would be a fuel or a turbo problem.
I had this with a Rover I had, this was due to the "honeycomb" in the Cat breaking up and blocking the pipe. As a simple check hit your cat with your hand, listen for a sound of a tin filled with gravel....still get it checked if you here no sound.
Hope this helps
Hope this helps
Black 480ES J Plate
http://img5.photobucket.com/albums/v14/Hereagain/
Steve
Cambs
Steve
Cambs
- dragon
My car is losing power, I'm sure of it (apart from the fact I have the boost to less than normal) - any slight incline in 5th gear renders the accelerator pedal completely useless and I have to change to 4th (and I do mean sligh incline, not great big hills). Even the volvo master technician who took it for a drive said it was massively lacking in power - what could be the cause of this?
Gaz Wilson
Gaz Wilson
Solved at last. The carbon brush had gone in the distributor cap and led to the cat completely deterirating, hence the gravel sound it has now. Took it to Volvo for diagnositc tests and they said, yes, the cat was knackered, cleaned all the crap out and it worked better, but didn't look further to what had caused it. As I was belting along at the new speeds of 70 mph, not seen for the last two weeks, everything went pear shaped, loud noises and no power at all. Called the RAC and they fixed it in 10 minutes!
Cheers for all your suggestions, we got there in the end!
New distributor cap on the way...
