Coolant bleeder hose cleanup
gsa60
Post by gsa60 » Thu Mar 07, 2024 9:52 am
Hello,
On the turbo models, there is that very thin (less than 5mm) hose/pipe that connects from the very top of the radiator back to the expansion tank.
I believe the main purpose is to help bleed the air when filling with coolant.
Mine's completely clogged.
Has it is a nard pipe and full of bends, does anyone have any good tips ou to clean that up?
Re: Coolant bleeder hose cleanup
Post by Jay-Kay-Em » Thu Mar 07, 2024 1:09 pm
Hi GSA
Removal, hot water, gentle "massaging" and compressed air!
Does mean nose cone off i'm afraid to get to the rad connection.
I would also recommend a full cooling system service if the coolant has been of such poor quality to be blocking hoses :shock:
gsa60
Post by gsa60 » Thu Mar 07, 2024 1:46 pm
Hi Jay.
Thank you for the reply.
Then it's more a question of patience.
Yep I'm redoing all the cooling hoses (got a set). My radiator is broken so I am in process of swaping it.
