Oil leak
royhedger
Oil leak
Post by royhedger » Thu Jan 25, 2024 5:08 pm
Just noticed an oil leak. Seems to be coming from half way down the block, at the rear near the cam belt housing, possibly from behind it. The cam belt looks dry.
Does anyone have any ideas what seal has gone before I get my local Volvo indy to take a look.
White 1990 480 Turbo Auto
Re: Oil leak
Post by Martin Mc » Sun Jan 28, 2024 5:59 pm
It isn't unusual for there to be an oil leak from the gearbox, as the seals in the Renault box do perish over time. It's worth getting under the car if you can & doing a visual check with an inspection lamp, before concluding where it might be originating from. Oil obeys the laws of gravity just like all other liquids, ad where it comes out / to ground might just be the bottom of the track. Worth a look 😉
Re: Oil leak
Post by Alan 480 » Sun Jan 28, 2024 7:25 pm
I have a persistant 'weep' from the area around the drive for the oil pump, (just aft of the cam belt, near-ish starter) I never actually got to the root, although I suspect it's an easy fix ? ??
(as long as the engine is on the bench) :hopping:
I think JKM has posted some images?
Small druibbles are not any concern,, it protects the underside from rusting.....
although having the cam-shaft seal blow out on way home (on SS1) was a touch excessive :cry: (especially as it is galv chassis and GRP) :lol:
royhedger
Re: Oil leak
Post by royhedger » Mon Jan 29, 2024 7:10 pm
Hi Martin,
Mines an Auto (Will have to update my signature) so it's a ZF box. The oil is black ish, so definitely engine.
I'm going to get under it when I get the time to have a further look.
royhedger
Re: Oil leak
Post by royhedger » Mon Jan 29, 2024 7:12 pm
Hi Alan,
Thanks, I'll have a look at the oil pump to see if it's from that area. I've sprayed some engine degreaser and cleaned the area I saw and then taken the car for a spin for about 30 miles but the oil has not come back as yet. Am going to use it a bit more this week so hopefully I'll be able to see where it's coming from.
Re: Oil leak
Post by Alan 480 » Mon Jan 29, 2024 9:43 pm
Roy
type this into the search bar
Aux Shaft Plug
and it will give you the correct section, about 30 odd photos into the thread :-)
viewtopic.php?f=23&t=34966&p=221205&hil ... ug#p221205
royhedger
Re: Oil leak
Post by royhedger » Tue Jan 30, 2024 7:38 am
Thanks Alan.
I shall take a look this evening and see if I can see the Plug.
R
royhedger
Re: Oil leak
Post by royhedger » Thu Feb 01, 2024 10:16 am
Alan,
Is this the plug in question? I thought it would be a solid flat top, but instead it appears to be conical with a cross in the middle.
Re: Oil leak
Post by Alan 480 » Thu Feb 01, 2024 5:36 pm
Roy
aye , I reckon it is, not easy to access with the engine in place,
I think Jay Kay explained how he fixed it, but his engine was on the bench/floor
royhedger
Re: Oil leak
Post by royhedger » Thu Feb 01, 2024 8:31 pm
Cheers Alan.
I've just managed to get a ring spanner on the 2 bolts and tightened them 1/2 to 3/4 turn each so hopefully that should nip it up a bit.
Re: Oil leak
Post by Alan 480 » Thu Feb 01, 2024 9:14 pm
Cheers Alan.
I'll need to investigate then, always assumed to 'difficult' :wink:
Re: Oil leak
Post by Jay-Kay-Em » Fri Feb 02, 2024 11:49 am
The torque of the bolts has little to no effect on the seal clamping force as the O-ring lives in a bore.
I say O-ring... if its 30 years old it will be a rock solid D-ring!
If you still have an oil leak, don't disregard this as the source because its been nipped up.
Its a 10p O-ring... get it swapped out!
Talking of oil leaks... make sure your turbo oil supply pipe hasn't rotted out where its secured to the exhaust manifold. Extremely rare they pin-hole but it has been known. As the years march by, this risk only increases for the 20 or so cars that have survived! Ultimate fire risk if so :eek:
royhedger
Re: Oil leak
Post by royhedger » Fri Feb 02, 2024 11:04 pm
Hi Jay,
I'll take it off and replace the O ring at some point, I've got plenty in the garage.
I'm not sure where the oil is coming from yet, I'll have to take a good look over the weekend but thanks for heads up o the turbo oil feed pipe, I'll be sure to check that.
