Broken Engine Part
MaranCarina
Broken Engine Part
Post by MaranCarina » Tue Jun 16, 2020 6:38 pm
Hello everyone :)
I bought 1992 1.7 turbo 480 a week ago. Unfortunately only 4 pieces 480 were exported in that time so i can not find spare parts and good repairman. There is a broken engine part( attached). I examined volvo parts catalouge; but i could not find this part's name. Could anyone help me? What is this name? Also i have one more problem. After 3500 rpm while acceleration, there is hesitation and my car can not accelerate well. Have any one experienced this problem and can this broken part cause the this problem?
Picture: https://hizliresim.com/6gP971 & https://hizliresim.com/JkpYYQ
I am waiting your kind response.
Best regards
Re: Broken Engine Part
Post by dragonflyjewels » Tue Jun 16, 2020 6:55 pm
oooo, a Turkish member !!! Welcome to the club, and congratulations on your purchase. I'm sure you will get a helpful reply this evening, I suspect jifflemon (our on-the ball turbo guru) will give you your answer very quickly.
I hope you enjoy your 480 when you have it running properly. Good luck !!
MaranCarina
Post by MaranCarina » Tue Jun 16, 2020 7:31 pm
Thank you very much :hopping: .. i am waiting 😊
Post by jifflemon » Tue Jun 16, 2020 8:44 pm
Ah....
have a read of this
MaranCarina
Post by MaranCarina » Tue Jun 16, 2020 10:21 pm
Dear jifflemon. Thank you so much for your quick respond. I have already read this topic; but i want to fix my car with original part. As much as i understand it is impossible :cry: What do you think about hesitation problem? Can this damaged part lead to hesitation? If i try your solution method, can hesitation problem be solved ? I am sorry for taking your time but this is my first car and i don't have enough knowledge about technical info.
Post by jifflemon » Wed Jun 17, 2020 5:32 pm
Potentially yes; The original parts are no longer available, and the "upgrade" whilst intended to help with modified cars, will work with standard cars too.
MaranCarina
Post by MaranCarina » Wed Jun 17, 2020 5:36 pm
Thank you for your help. I will try to fix it :)
malkontent
Post by malkontent » Sat Jun 20, 2020 3:56 am
Hi
Maybe I can help you , must check in my " treasures " , have B18FT for spares .
Best
MaranCarina
Post by MaranCarina » Thu Jun 25, 2020 3:06 am
Thank you guys. Problem was solved :hopping:
