B18ft sump
B18ft sump
Hi folks, looking for a sump for my B18ft, does anyone know if sumps from a 1.7 na or 2.0 or any Renault engines fit? Cheers
'90 940 GL 2.0l Estate
'08 XC90 D5 SE Premium
Re: B18ft sump
Hi
It depends only on Chassi number , B18 , B18FT , B20 , AT4 , MT5 = 3342373 CH - 584799 , 3464333 CH 584800 -
Have B18 and B20 sump
Re: B18ft sump
Hi there,
i am unsure what you mean? it has a manual 5 speed gearbox if that helps?
Re: B18ft sump
See my post ,it depends only on Chassi Number . Engine and gearbox is not a problem . Look at your VIN , last six numbers .
Re: B18ft sump
the engine i have is spare and out of a car, so therefor i do not have a chassis number for it.
what are the differences between chassis numbers?
Re: B18ft sump
Chassis numbers, from elsewhere on this site:
500000 - 501200 = 1986
501200 - 517501 = 1987
517501 - 536101 = 1988
536101 - 549001 = 1989
549001 - 563101 = 1990
563101 - 573100 = 1991
573100 - 581000 = 1992
581000 - 586300 = 1993
586300 - 590001 = 1994
590001 - = 1995
It would be interesting to know what the difference is though.
590001 - = 1995
Re: B18ft sump
looking on ebay at new items for a renault 19 which after speaking to the seller he assures me it fits any 480 1.7 engine
my car is a 91 however the engine i am unsure, it's being used for a low compression forged turbo build...
Re: B18ft sump
My wisdom is from VADIS / Volvo electronic parts and service program / the same is used by Volvo Dealers . My ES , 1990 , 1.8 engine has Chassis Number 559248 , so sump will fit to all engines up to this number . Give me your engine number I`ll try to find what year it is . That number is bolted on a small plate in front of the engine . Unfortunatelly I can`t make a picture of Colli sump , front frame is broken and engine is lying on a floor . I think the best way is to look at all sumps having in hand . Maybe Glasgowjim could help ?
