Hello folks,
The sorry saga continues. Having taken out the (blue connector) temperature sender from the top front of the cylinder head, I now find that removing it appears to have stripped the threads in the head The 'OEM' replacement sourced from EvilBay doesn't fit (different thread pattern / diameter to the original, and the threads on the original are now flat as a pancake.
I was wondering if anyone else had run into this (or similar) problems with fittings into the cylinder head. I have a tap and die set lined up to try to rethread the thing, but a bit nervous about getting anything to fit thereafter.
Any ideas?
Re-threading temperature sender seat
Re: Re-threading temperature sender seat
TBH you'd need to get a 'helicoil' inserted OR tap to a size big enough to make an adaptor if the threads stripped in the alloy
not sure if you could blank the original hole and find a 'different' location for the new sender, it needs to be somewhere that gets 'as hot' and that will not be easy . . . .
If stuck, drill & tap to suit an M12 bolt, drill a hole in the M12 and tap that to sender size?
not good whichever way
edit
had second thought, if the temp sensor is BSP then drill and tap to a BSP fitting size as you can get BSP to BSP adaptors for a few pence
edit
Hello Alan,
Many thanks for your cool and considered replies! I can see BSP adaptors available, as you say, for a few pence or so on eBay - so that would be the most likely way to go I think. I'll let you know how I get on..
