B18FT ignition coil, HELP
Sharpspike1
Post by Sharpspike1 » Sat Feb 27, 2016 10:28 pm
Hello guys, I have a B18FT engine, but I dont have an ignition coil, could some one tell me what kind of ignition coil can I use? There is a problem getting a stock one so maybe there is an alternative? As I saw in the picture the stock one have 2 , 1- is ignition module and 2- is the coil, is it possible to work with just a simple coil? Thank you for answers
Robou
Re: B18FT ignition coil, HELP
Post by Robou » Sat Feb 27, 2016 11:24 pm
Any coil designed for a transistorized ignition system will do.
Too old to bother
480 Turbo midst '91
Post by jamescarruthers » Mon Feb 29, 2016 8:25 am
Ignitioncarparts.co.uk
What's your project?
jamesy12345
Post by jamesy12345 » Fri Mar 04, 2016 4:17 pm
Got one if you need one still
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
