aux belt change B18FTM non airco
gltease
Post by gltease » Sun Sep 07, 2014 5:11 pm
Hi guys,
Changing aux drive belt on B18FTM non aircon do I need the crank tool as per haynes manual? I'm assuming this isnt a difficult job to do ?
C
'88 Volvo 480 ES
'97 Volvo 940 Turbo
Re: aux belt change B18FTM non airco
Post by Alan 480 » Sun Sep 07, 2014 6:25 pm
if you mean the lock for crankshaft?
I used a long plain bolt in through the side of block making sure that it picks up the correct hole not the balance hole.
slacken off the crankshaft nut BEFORE you insert the rod! it might be tight , in fact it WILL be tight, I had to use a big extra long lever on the nut and SWAMBO with foot on brake in fifth.. . . . . .
Post by glasgowjim » Sun Sep 07, 2014 8:50 pm
No he means one of the 2 belts which operate the water pump and alternator not the timing belt.
From memory you dont need a special tool rtarely believe the HBOL.
However you may on occasion cuss a little. :lol:
gltease
Post by gltease » Sun Sep 07, 2014 9:10 pm
glasgowjim wrote:No he means one of the 2 belts which operate the water pump and alternator not the timing belt.
Thanks all, are there 2 belts to be changed ? Not including timing belt
'88 Volvo 480 ES
'97 Volvo 940 Turbo
Post by glasgowjim » Sun Sep 07, 2014 10:35 pm
Oops just read its non aircon so only one belt thats so much more easy than the air con which has 2 . It is an easy job.
HBOL is totally duff. :shock:
Post by Alan 480 » Sun Sep 14, 2014 6:01 pm
jim
should have read properly, misread it as timing belt ;)
any way the hint is correct in case the timing belt is also to be changed, which is always worth doing if NO record of when it was done!
