Injectors
kingrichy
Injectors
Post by kingrichy » Sat Jun 02, 2007 9:04 pm
Does anybody know if the injectors for a B18E and B18FP are interchangeble, or do they work with different pressures.
My baby`s
1990 Red ES Automatic 145000km
1990 Lavendel metalic 223000km
1988 Grafite gray metalic Turbo 185000km Sold
http://img20.photobucket.com/albums/v60/kingrichy/
crispy-d
Post by crispy-d » Sun Jun 03, 2007 1:43 am
Well, according to Haynes:
B18E: 2-3ohms / 2.5bar
B18FP: 14-15ohms / 3.5bar
I'd say they're not interchangeable, unless you start adding resistor packs and changing the fuel pressure regulator - if you can even do it like that...
Anyway, hope that helps a bit.
Crispin
BMW E39 M5
Land Rover 110 V8
kingrichy
Post by kingrichy » Sun Jun 03, 2007 11:33 am
Thanks for the info.
That was my problem, had the wrong injectors in my engine.
I put a B18E engine in a B18EP car, and forgot to change the injectors.
So now i have a running car again.
Richard
My baby`s
GTImk1
Post by GTImk1 » Wed Feb 18, 2009 2:21 pm
So what injectors does the B18FP use? What reference, cc/min?
Best regards
GTImk1
Post by GTImk1 » Fri Feb 27, 2009 5:21 pm
Hi,
From what we have discovered, B18E uses low impedance injectors and B18FP uses hifh impedance ones.
Basically if you use low impedance injectors you can toast the ECU, for this you would need a set of resistors i believe (don't know exactly how and where).
I'm looking for injectors for my B18FP engine aswell, and i might try the Turbo ref. Bosch 0280150741 ones as they are high impedance.
Best regards
